Warm!? Black Full Tower For $19.95+Shipping!
I would bite if I knew that case wouldn't cut my hand to peices, eck for cheap metal.
With a $0.50 piece of 300 grit sandpaper you can knock all of the rough edges off all of the metal parts you would ever come into contact with. Many here will tell you though, including myself, that it is still very possible to cut your hands on even $100+ cases as well. Best of luck, mate.
I still can't grasp the fact that people cut their hands on cases. I've had plenty of cheapo cases and never come close to doing so. What exactly are you guys doing that puts your precious phalanges at risk?
It's usually from cheap cases that used stamped steel. When the pieces get cut that wat they tend to have a sharp edge on them. The alternative is a case with rolled edges, but obviosly this adds extra cost.
