[Warm] Acer 22" Widescreen
i saw this at circuit city for 319$ yesterday. looked nice, stand seemed shitty - spend saved money on vesa mount. tiltless and heightless. and i couldnt check it for ghosting or anything cause they connect all monitors up to shitty videochips. but they have it there so go check it out in person.
I use a black bezel version of that LCD at work and I love it... naturally I'm not gaming on it at work, but I've had 0 issues with it sofar.
This is a great monitor, I bought it from newegg a week ago. The monitor comes with a DVI-I cable though, you will need a DVI-D if you want to run 1680x1050 or everything will be blurry :(
There shouldn't be a difference in picture between DVI-I and DVI-D...
The connection on the back of the monitor says DVI-D but it comes with a DVI-I cable, maybe it shouldn't make a difference, but after I used a DVI-D cable it cleared up and that's the only change I made.
Ive had this monitor for a couple months. No problems, I used the DVI cable included and its not blurry for me at 1680x1050 and the stand is tilt adjustable, its not very easy to adjust though.
Found out that my blurriness comes from my 8800, not the monitor or the DVI cable. Apparantly the drivers I was using set the display at 1600x1200 when I selected 1680x1050, so it was not the native res of the monitor even though it said it was in display properties. Hooked up a 7950GT and it's freakin beautiful, sharp, crystal clear display and excellent response times.
