warframe and 2080 ti
Psycrow
Using this monitor https://www.asus.com/dk/Monitors/ROG-SWIFT-PG27UQ/
and 2080 ti Auros extreme https://www.gigabyte.com/Graphics-Card/GV-N208TAORUS-X-11GC#kf
When i start Warframe then my screen settings is 3840 x 2160 - 98 hz - 10 bpc - Full RGB - 32 bit
and i also use the same settings in the game. So i havent set the game hz to more then 98 hz in options.
But i play in 4 k ress with all option set to high and enabled.
After 1-3 hours i quit the game and then i see my current screen settings has changed to 3840 x 2160 - 89 hz - 8 bpc - 32 bit - 4.2.2 with limit dynamic area.
And it wont let me set the settings back to the 98hz with 10 bit, since i cant choose any hz above 89.
But when i reboot then i can set all options back to 98 hz 10 bit or 120 hz like normal.
I dont know if it is warframe or nvidia drivers or my gfx card that is bugged.
Has anyone tryed something simular or same ?
with the hz being changed and you cant change it back before you reboot ?
has no one ever had a problem with a game that was changing the hz in windows?
