Ocellaris
- Jan 1, 2008
Warcraft performance gets talked about quite a bit, however it hard to generate good comparison results from it. Here are some simple steps people can run in a couple minutes to get a baseline FPS to compare with others and see how their setup is running.
How to:
1) Disable all of your add ons before logging in
2) Log into an Outlands character
3) Click Options -> Video
4) Click Defaults (this will also reset options you may have set via the command line to outside the slider range)
5) Disable Vertical Sync
6) Set Resolution to 1280x1024 no AA (or just pick what you want and make sure you post it in the results)
7) Set all World Appearance sliders to the far right
8) Click Okay
9) Log out, close WoW, then log in again to have all the settings apply
10) Now get to the flight master in Shattrath
11) Type "/timetest"
12) Talk to the flight master and fly to Cosmowrench in Netherstorm (this is a location both Horde and Alliance can land at)
13) Post results when done. Your min, max, and avg FPS will display in the chat window
How to:
8) Click Okay
