Want to upgrade
Rydawg5143
Get another 4870 512 and crossfire for about $175
Sell current 4870 and buy 4850x2 for about $150 ( price after selling old card)
WHich do you guys think
Go for the 4870 Crossfire. No reason not to, if you already have one 4870. The 4850 X2 is a great card, but it isn't as good as two 4870s.
Rydawg5143,
Two important points that you need to consider are resolution and motherboard
A. resolution, I was in the same boat as you, with a 512mb 4870, but moved up to 2560x1600, and the 512mb is too little for that resolution, so I move the 4870 512mb to another system and bought a 4870x2
-the 4850x2 is as good as the 4870x2 with the benchmarks I seem, but had a major flaw with only driver support by sapphire, no ATI support, but I believe that change with 9.1 catalyst, so it looks like a good choice now
B. motherboard, if you have p45 and up, and you don't game at too high of resolution, than another 4870 512mb would be a great choice
good luck
sam
