Want to try crypto...but couple questions
troisanh
Possible to run 2 3090's on asus z170 board with G4520 using 1000w p2? Been doing research but still many questions.
Can i run gpus off the 2 pci-e onboard and use nicehash for OS off spare 120g sata SSD.
J Macker
That should work. Reduce the power limit on the GPUs to prolong life & reduce heat.
Schro
Each 3090 will draw 270-300w while mining, board+cpu/etc won't draw more than 100, therefore, 1000w is fine.
