I want to up my current HDD solution to a Raid 0 solution, but I have no experience in this so looking for some helpful tips on what i should do.
Specs are in sig.
So what I want to do is buy 2 new 640gb HDD to Raid 0 and reinstall windows on my computer. Iv read a few things that I should use sata ports 7 & 8 on my MB because that is horrible ( apparently ) I Dont want to wipe my current drive because it had a lot of data on it already.
So basically im asking:
Suggestions on what HDD I should buy, needs to be 7200 rpm and 500+ GB
How do i actually set up raid 0, can anyone direct me to some info that is actually easy to read
When I do get the hard drives should I set up the raid while still booting up on the old drive then once the raid is added then install windows on the new drive
Or should i just install windows from the get go
Thanks guys =D
Specs are in sig.
Thanks guys =D
