I would like to go to a raid confirguation but never installed raid with os (vista 32).
Can i now install it without reinstalling os? I would be very grateful for any suggestions.
Would setting up raid transfer data from orignal hdd to raid array?
The only way you could transfer your HDD to a raid array would be to copy the partition, but that requires 2 new hard drives and your existing drive. Plus the resulting partition would be the same size as what you started with, and expanding a partition on a raid 0 setup can be dangerous.
The best thing to do is back up your data you want to keep, buy the 2nd drive, and install a fresh copy. Also, based on the drives you have in your signature and depending on what you do, you probably wouldn't notice any benefit from raid, so it might not be worth the hassle for you.
What exactly do you do, that you feel you need raid for to increase performance? Those raptors are incredibly fast for a desktop setup, as is.
I have two new raptor x drives 150 gig just sitting around , I thought i would put them to use as raid and use the old 150 as back up.I was thinking of raid 1 as i have tried rais zero and do not belive it's for me.
