Wallmount Z5500 Questions
Agashka
Hi, I've bought Z-5500 a year ago, and I love them. since I don't have anything at the rear of my PC table, my rear speaker are not plugged. I figured out I could wall-mount em. They seems to have little holes on the foots for that.
1st question: Is mounting them with 2 screws on Dry Wall(gyproc) a good idea? I don't want to spend much money and effort on that mount, because the basement is a mess, and I can't make anything down there.
2nd question:
what would be the best place to mount them, this is my room, and I though to put them in the 4 corners, but... I'm not sure it's the best thing since my door is mostly always open. So I figured out I should ask the expert over [H].
My desktop is in the right top corner. The main reason I want to plug them in corners are because It takes less space and it's less bothering, and it's gonna be awesome for guitar playing.
Thank you,
-Vincent
How much do the speakers weight? Screw in drywall can be a little uneasy and vibrate out after a while. You could try plastic anchors in the drywall and then screw them in. Also, if you can find a way to use toggle bolts that would be a little more secure.
