Wallet Upgrade
Lucky75
Hello guys,
I need to upgrade my BTC wallet for that I need reference pin of my wallet.
How I can check what is reference pin of my wallet ?
Your pin is what you setup on the wallet and there is no way to extract it. If you no longer have it, you will need your seed words to restore your wallet and establish a fresh pin/passphrase.
I think we are talking for different things. You are telling me for security pin for the funds inside. I am asking the pin like version of the wallet.
Got it, then I have no idea what you are talking about. Probably would help others by specifying which wallet you are using (as there are many).
