wall mounting help please
dust
After looking around at peoples setups i was thinking i want to wall mount my monitor. I have a samsung lcd 17" monitor and i was wondering if you have to have a certain wall mounting setup for a samsung or can it be anykind? if you guys/ladies could help me out it would help me out greatly. =]
They don't have to be any certain kind. It's kind of universal. This might work.
There's also a VESA standard like 75MM and 100MM. You might have to find out what yours is first. The one above should work for your monitor.
I'd probably go with that.
You'll want to check your manual or samsungs website to find out exactly what type of mounting you need.
Most monitors use the 75mm VESA mounting holes though, but there are some exceptions.
ok my monitor to be exact is a Samsung Syncmaster 17" 171v black. And i couldnt find it on samsung.com its like 5 years old so i dono if they would have it on their site anymore. So if this is just like most monitors would it fit in that 75mm Vesa?
171v specs
Scroll down to about halfway. It says VESA mount.
