waking up to a dead system - need advice
jfkriege
I woke up this morning to a system that would not do anything. I have a self built desktop that is an Asus A8N SLI Deluxe with an Athlon X2 4600 on it. I went to power it up and the fans came on but nothing else. There were no beeps from the motherboard, i could hear he hard drives spin up but there was not the clicking noise showing access. Fans and nothing else.
From this i am thinking that i am in need of a new motherboard, but i am not in a place to be able to spend a great deal of money and not feel it sharply. That said, i need this computer as it is the main computer for my side business of photography. So here are my questions:
I think it is the motherboard, what do any of you think it is?
I know this was not a product of a surge as it is very well protected. What is the likelihood of other components being affected?
Would it be worth it to take it to a repair place to just have them run diagnostics on it and see what components are still working? (I dont have the ability to test things as my one motherboard might be down)
Thank you very much for any and all replies.
Joshua
First, try clearing the CMOS on the motherboard. If that dosent work try swapping out the video card.
Report back ;)
to tell you the truth, thats weird and it could be anything..
I use to have a problem that if I had a power outage I'd have to unplug my computer for about 30second before it would boot up again. You might can try that, maybe you had a breif outtage last night.
i will have a go at clearing the cmos and also trying the unplug thing.
originally i limited it to motherboard because there was not even the beep that normally happens when i turn on the computer, and there was really no activity but the fan. i have had ram go bad and it beeps like it was insane, i would imagine it does the same for the cpu. i have a spare video card, but the one in it is less than two months old and certainly has not been taxed recently. it is a 7900 gto.
i am at work now, but i will be home about 4:30 and will have to try things out then.
thank you for help, anything else?
Joshua
If the cmos does not work, check RAM and also any add-in cards also. Could be anything.... Might be PSU also
it looks like i am going to have a fun night of stripping the computer down to almost nothing and building it up again.
there are a few things that i cannot test, does anyone have an idea of what it would cost to have a computer place and have them run diagnostics on the system, or if it would be worth it. (my main one is that i am not sure i can test the ram individually)
joshua
i have cleared the cmos and traded out video cards and none of this helps. the computer will not even get to the part where it posts the video card information. as well, it will not shut off by the normal holding of the power button. in order to shut off the computer i have to turn the power off at the power supply. any more ideas on things that i could do?
joshua
Complete failure to post can many times be traced back to bad ram. Try using only one stick at a time, switch slots, etc...and see if that helps.
