I do... clearly states so on the actual proc. But Windows XP only sees it as a 2500+. I built a new computer and got it up and running without much of a problem. I went into Control Panel -> System and it says AMD Athlon XP 2500+. Is there a BIOS setting I am missing or can change or did newegg just screw up? I took it out and re-seated it, but if that was the problem, it wouldn't see any proc at all.
My specs:
DFI Lan Party NFII Ultra B
AMD Athlon XP 3200+
1GB Mushkin (sees that fine)
My specs:
AMD Athlon XP 3200+
