wait for DX 10 video card??
charliebrown78
Vista is coming out next year. When will DX10 video card be available?? I have 9800xt and was thinking about upgrading to 7900gt. Should I wait for DX10 card to come out??
Depends. I made a jump from 6800gt -> 7900gt and it was worth it, so yours is even bigger.
I wouldn't think that DX10 cards coming out would require you to upgrade immediately... you'll see a good performance boost right now. But only you know when you'll be able to afford to upgrade again.
Depends on where you're starting from. Since you got a 9800 xt I'd definitely hit a new 7900 gt.
Asian Dub Foundation said:
if i were you i would upgrade now... DX10, like DX9, won't be in full swing for a while
yeha, but the dx10 cards wil be at leat 2x as fast as current fastest.
i say go for a used 7800gt for cheap
or you can just wait, i mean, if it works now, why mess with it
I would wait, I have a 6200 right now and I am waiting for them, not jsut for speed but for all the cool effects (Sub-surface scattering etc)
Excellent point. In the world of video cards nothing stands still, so why would you?
Upgrade and enjoy yourself.
If you're happy with your current card, if it does what you want, then just wait. Dont upgrade until you have a reason you need to - for instance, if you really want to play Oblivion with eyecandy on at decent framerates, then by all means, upgrade, but if what you have handles the games that you play, then there's no point in upgrading. The longer you wait, the further ahead you'll be. It's a case of If it aint broke, dont fix it.
AFAIK DX10 is a rather drastic swing in rendering approach so i wouldn't trust the first release to be sufficiently efficient. I'd rather wait for 2nd or 3rd generation DX10 cards. And that's still a long way out. No sense in waiting that long.
you are going to suffer with a 6200 just to wait on a card that cant even use its DX10 features until Jan/Feb 2007? :rolleyes:
I just upgraded from a 9800 PRO to an x1800xt, and I am very happy with the difference. I think you would be too. The 7900 you're considering would be an even bigger jump than what I had.
Tsumari
if you have a card that is a couple of generations old or a very slow modern card why wait? :confused:
2gigs said:
eeh, becuase he can save even more money
are you in ALL my threads. lol. like i said earlier there is no point in suffering for 10 months just to wait to use the DX10 features.
I'm a bit skeptical about DX10 cards (at least, about the benefits of buying one before DX10 software is commonplace). If the DX10 architecture is as radical a departure from DX9 as they say, then it seens to me that many DX9 functions will need to be emulated on the new hardware. Which is definitely not going to help performance.
If this is the case, then it's a bit much to hope that "the dx10 cards wil be at leat 2x as fast as current fastest". It wouldn't surprise me if they even fell short of the preceding generation when it comes to DX9 performance.
I'm in this spot too. My computer now isn't very good at all, and I'm planning on building a PC around July or August this summer. It would be nice to get a DX10 card, but I'm still wondering how good the first generation will really be. It may be better, at least I think, to purchase a 7900GTX or a 1900xtx and then upgrade to a second or third generation DX10 card. How long would the two aforementioned DX9 cards last at mid-high settings in games? A couple years at most? Or would it atleast be playing games at mid-high settings until the DX10 second generation cards are released?
Wouldn't it ultimately be up to his money? I mean, if he can afford to upgrade now and later, I'd say he should do that. but if he won't have money later (in which case, why does he have money now? haha) then he should wait.
...Then again, he is using the 6200.... Turbocache FTW! :D
Keep in mind that even after the cards come out, it'll be a while before DX10 is widely used. Most developers will be reluctant to put that much time and effort (ie. money) into something only a small proportion of gamers will be able to use.
So if you put off buying a card now... once you get your new DX10 card, it'll probably be a while longer before you actually see the benefit...
I would just build a new system now, why wait when thiers awsome stuff around now and you can upgrade later? (unless you can't afford to upgrade now or your perfectly content with your system)
noesis said:
I jumped from a 7800gtx to a 7900gtx and am happy i did so.
Riiight, because that extra 3FPS you gained in camper strike was so worth it
:rolleyes:
Some of the first so-called dx9 cards did not do dx9 very well.. The first batch of dx10 cards may not do dx10 well either.. I have a 1900xt now from a 9800pro.. The difference was worth it.. I suspect game devs will program a dx9 path for the next couple of years at a minimum...
If you want the performance and eyecandy now, I say go for it.. It is not like dx10 games and cards are coming out in the next month.. We are talking 8-10 months before dx10 hits..
And it could be a number of months after that, b4 many games,(except MS's Halo2), really take advantage of it or even require it....
well, i must say i just got my x1800xl and im very happy with it.. especially coming along from x850xt. i mean the cards a beast to me anyways..i think no video card is to fast.. so even when you wait for directx10 you will still be getting video card after video card.. thats the whole fun in it! lol itts called upgrades lol like the guy before me was saying just enjoy your self.
3FPS is not really alot, although it really depends what your minimum fps and avg is.. if you avg 35fps then 3 is alot ;) but if you avg 80 then no its not
Unless you also want to wait for Vista, and all the DRM baggage attached to it. I was gung ho for DX10 until I learned it wasn't going to be released for XP. AFAIC, Microsoft can take its 7 flavors of vista, apply some astroglide, and install them where the sun shineth not.
DX9.0L FTW!!!
Remember, the first DX9 cards were slower when rendering DX8 games. I still remember my TI4400, and how it kicked that DX9.0 "compatible" FX5200 to the curb.
Please tell me what was wrong with ATI 9700pro the very first DX9 complinant card. It was out befor DX9 . It was amazing how fast games came out for it.
i was gonna wait til dx10, but yesterday i had a chance to get a x1800 xt 512mb for 242, so I did. i guess ill get dx10 cards when vista comes out. i also noticed I never keep a card for very long if i pay more than $300 for it. I paid 460 for my x1800 xl (i was one of the first to get one), and I returned it after 1 month cause it dawned on my, this realy isnt worth 460. But the cards i pay 300 or less for i keep much longer. my 9700 pro i paid 300 for and kept it for over 1 year.....not sure why i started talking about my purchasing habits?
DX9.0L FTW!!!
oh please, my voodoo3 could probably kick some fx5200 arss.
True that, but theres no reason for me to upgrade to better cards as thier is no single-faster card then what I already have. (but I did upgrade from a 6800GT)
ok but i was never referring to you. this is what i said right before that post: "if you have a card that is a couple of generations old or a very slow modern card why wait?"
