Wait for BIOS/CPU revisions for x79?
MarkGerazzi
Hey again guys,
I've finally got my cart filled out at newegg with what I thought was the perfect build, but so many are telling me to wait off for the newer versions of the motherboards and 3930k.
Some stuff I found floating around the net:
1. Hardware C-States (Not dependant on BIOS implementation)
2. Support for DDR3-1333 with 4 Ram Modules (C2 would drop back to 1066 with 4)
3. general clocking improvments typical of a new stepping (100-200Mhz higher headroom)
I don't know if these are important or I will benefit, number 2 looks daunting, my 1600 ram will downclocked? Since 3930k is only c2 stepping.
Is there anything else I should consider with "revisions"?
I have a record label shooting me $1000 for the build and they'd like for me to be done by the end of the week, something is telling me to hold off as much as I need this for work.
Hey again guys,
It seems this is a customer build. You can do what you wish but if it were my customer i would have already ordered the parts.
That stuff you seen floating around the net looks like complete crap not to mention it has no relavance to a computer being built for a record label.
a 3930K supports DDR3-1600 natively. So if you buy DDR3-1600 thats what it will run at. Your question isnt very clear.
I"m just confused with this statement. I'll be using 8 dimms
you say you found this info "floating" around the net.
Do you consider the source credible? Have you asked the maker of the motherboard you intend to buy about it? I don't even see the motherboard listed. Do you build/sell computers for a living?
The processor supports 1600 out of the box and that has nothing to do with stepping. If you're unsure how the motherboard will handle 8 sticks of ram then check on the motherboard manual pdfs online when you've picked one out.
