Has anyone tried to use dual screen or widescreen with a wacom pad? The reason I'm asking is because I have a dual monitor setup and an intuos 2, and the problem is that the aspect ratios aren't matching up and it makes the cursor movement feel funny. Let me explain:
The graphire pad is of course, a 4x3 aspect ratio, (I'm almost certain that it's a 8"x6" pad)well, the monitor, because it's dual, is like 8x3 (two 4x3's) and the horizontal movement is not lining up because the tablet utilizes both the screens. Anyone who's ever used a wacom pad probably knows that the edges of the monitor correspond with the edges of the 'writable areas' of the pad.
The question is, does anyone know of a way to force the tablet to use only one screen, or at least just one at a time? Is the strange sensation of mismatched aspect ratios something I can get used to? How are the people with widescreens handling the difference, which I imagine is somewhat similar to what I'm experiencing but to less of an extreme since 16x10 and 16x9 is closer to 4x3 than 8x3.
Thanks ahead of time!
Art
Art
