I've made another post in another forum about dealing with a laptop restoration/migration to SSD from the HDD that came with it.
My question here is specific sub-question. I'm not trying to do anything illegitimate, I just don't want to waste an hour to find out that something I might try to do would never work.
In XP days, I had trouble trying to use media which did not belong with the appropriate OEM license code. If I had an IBM system with an XP license sticker on the side, for example, it seemed like I couldn't just grab any XP install media and use that product code to activate. I didn't spend a lot of time digging into it, I just observed the problem.
What's the situation on Win7? If I have an OEM-licensed piece of hardware, can I use my TechNet install media to install the same edition of W7 and still activate using the legit OEM product code? Or do the big OEMs (like Asus, Lenovo) have specific install media to go with their codes and I MUST somehow use the product recovery disks to do an install?
Thanks,
Thanks,
