A few months ago I downloaded W7 Pro 64bit upgrade. I installed it as a clean installation, and everything works great. Earlier, I tried to upgrade my brother's computer using the same key on a 32bit installation. However it didn't work? It kept saying the key was invalid. Do upgrade keys only work specifically to a 32 or 64bit version? I was under the impression that is was perfectly legal to install separate 32/64 bit versions using the same key, though maybe this only applies to retail versions? I had to download the 32bit ISO, so maybe I downloaded the wrong version? I'm not sure whether or not mine is upgrade - it may be retail, I have to double check.
