W600 AMD recommended pairing
fudge2011
I need a recommended pairing for running three monitors on top of 6 connected to an AMD W600
I need to know what cards can be used together with the W600 to run 9 monitors in total. I need to run eyefinity and game with them too.
Any suggestions? thanks :)
Ideally the card should support directx 11 and open gl 4.2. I dont really want to have to link anything in crossfire - if possible
what games you plan to run 9 monitors on? that card surely would not be able to play much more than ancient games right? that appears to be a workstation card is it not? i'm not knocking you...was just curious..i would have thought a Radeon R9 295X2 Graphics would have a tough time doing that:)
I'm not sure how well Radeon and Firepro cards mix on the same system because they use different drivers.
I have changed my mind now and gone instead for two
Ati FirePro 2460 512MB Quad mini Display
I am going to split two screens into one with a dvi y cable and luckily I already have all the mini dp to dvi adapters.
This way I'm saving a few hundred pounds. I think I will get windows aero but I wont be able to do hard core gaming ( not bothered). :p
