PC-HAngover said:I foresee a lot of leaking in your future....![]()
Look at the rest of the system: that tubing is probably home depot vinylDryFire said:I'm guesisng the tubingis clearflex?
thewhiteguy said:Look at the rest of the system: that tubing is probably home depot vinyl
Nothing against that tubing, I've got it myself. No need for the more expensive stuff if your tube routing is nice and straight.
cornelious0_0 said:That's not a very positive thing to say. Chances are you might just have been joking....but whenever there's someone around here trying something new I try to keep their spirits up as much as possible. I've been there, and even the slightest comment can throw someone off track.
Kudos on the Economic setup there bro.....better then my Zalman CNPS7000 for sure.....truely something to call your own.
v3rt1g0 said:Props for not going store bought.
I totally love your res placement on the 3.5" tray.![]()
Deadlierchair said:maybe there should be a sticky of ghetto systems somewhere hehe
Not quite, it's not duct tapecornelious0_0 said:Personally I love the tape job on the tupperware.....truely [H]ard.![]()
DryFire said:apparently they have a 295gph version too.
http://www.marinedepot.com/md_viewItem.asp?idproduct=AS1117
I'm gonna venture a guess that it is at 0' head.
thewhiteguy said:Damn, I should have bought one of those pumps instead of my Swiffy.
Grizzy said:Hey - I am about to buy a maze 4 GPU block, do you guys think my 160gph pump will take it? It's doing great with the CPU and my big heater core, but I am a WC n00b and wouldn't know if the GPU block would restrict it too much
I know I have a great pump, but for the same price I could get four of those Maxijets and run them in parellel and series at the same time, that'd be a LOT of flowDeadlierchair said:I don't know if that's certainly true. Most wisdom says you get what you pay for, but also in the water cooling business everyone trys to rip you off. The Swiftechs are great pumps, I wouldn't regret that purchase at all. I just didn't have the money for one of those pumps, that's why I went this route.
Deadlierchair said:I might get a better pump for all of that. What kind of pump do you have? Not all 160 GPH pumps are the same in quality and performance, but I'd guess a better pump would help.
Grizzy said:Ok, I will get a higher flow pump - After all, a 295gph pump is only $20It may not be equal to expensive 300gph pumps, but it should be able to handle my system fine, right?
http://www.petsmart.com/global/prod...<>ast_id=2534374302023693&bmUID=1093899274869
DryFire said:I didn't see any reviews of the maxijet in a water cooling setup or compared to any other pumps.
WesM63 said:Man, and I thought I was ghetto![]()
J/K, At least its performing decently.
cornelious0_0 said:exactly, its that kind of "ghetto functionality" that one needs.....no use in having a cool looking ghetto setup if you can't leave it alone for 5 minutes in fear of something breaking loose/down.![]()
