W00t my second major case mod!!
i like what you did... dont like the different colors on the front though ;)
edit i want some cheerwine :eek: :(
it is a silver fan controller and a soundblaster live controll panel, neither are paintable =P
yea we stayed up all night doing this (not bad for only 14 hours of work =P)
we drank all of those cheerwines... mmm cheerwine
i want some :mad: ..the gay fags dont sell it up here :(
I like the window design, although I think it would look a little better with the edges of the window rounded out.
i like itr however it makes a job look much better when the pictures of it are good.
you can clearly see the case and "most" of its features in those pictures however most of them are washed out, try turning up the contrast in photoshop.
other than that great mod just consider taking a little more time photographing it :cool:
sorry its my crappy rca cds1005 it has NO resolution and if you move the tiniest bit it blurs
but i think you get the general idea from the pics
actually, come to think of it, i had to get the pictures off my camera with linux because the drivers wouldnt install on windows xp (use gphoto2 on linux)
WooT, You h4x0r3d a G4t3w4y! HA HAHAHAHAHAHA! I thought I was the only sick one around here! :p
Lol, yes, and may i add, the case was a bitch. We're talking solid steel. I used around 32 heavy duty cutting disks and 5 reinforced ones. And then, just for fun, we found out the case was too thin for the psu (mad h4x0r1ng).[i got the psu to fit by replacing part of the rails for the side of the case with the edge of the psu] If gateway didn't make such solid cases I would have told him just to buy a new one.
