exiledtaru
- Jun 16, 2006
Righty,
After lurking on here for a few weeks and checking over various posts, ive become slightly more confused then when i started /doh.
I currently have a TT Tsunami case, currently amd 64bit 3000, (moving to 3200 venice core soon) and a GF6800 ultra card. i would like some ideas on what to purchase for this kind of setup, ideally all internal but that might not work. No probs in moving the HDD bay out, (should free up enough space for res + pump. i have searched for some piccys of others setup but have been unlucky, maybe its the case.
I was looking over some posts about the kit, seems that Swifttech, danger den ( i think it was) and aquacomputers. Now after looking into those i was considering....
Swiftech H20-220 APEX "Ultra" CPU Liquid Cooling Kit - with added GPU cooler (if possible ?)
AquaComputer High End 240 Kit Eheim 1046 (with Aquacomputer AquagraFX6800 Rev 2 Block and Aquacomputer Cuplex XT Block Athon64 ) this is a bit more expensive but german engineering
Maze4 - 1 A64 CPU Tec Block, NV-6800 GPU Block, Eheim 1250 Pump, Thermochill 120.2, Aquatube Blue 8mm (res) and whatever tubing i need.
What do you guys think ? can anyone offer me any advice, i wont be doing any major O/C but would be nice if the option was there.
Thanks for any help ^^
