Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Like Eresmus stated, the only real important thing is the T-line/reservoir before the pump inlet. The miniscular performance difference you might see switching the pump and block(s) order would likely be offset if long tubing runs and/or tight turn(s) are needed to get a specific order. Whatever routing is the easiest and shortest is usually the best, as long as the T-line/reservoir is before the pump inlet.
