For years now, I have been using all fan cooling for my telescope computer, but I am going out and purchasing a watercooling setup.
I am wondering if watercooling a computer that will be used outdoors in below freezing tempreatures would be a good or bad idea.
I have done this before with simple fan cooled parts and it worked fine, but liquid cooled?
My mixture would be like 40% Distilled water, %50 Non Concetrate Ethylene Glycol, and a little water wetter.
So, what do you think, can be done?? I am thinking just kill the fans and let the CPU and GPU keep the liquid warm, and let the outside air do the cooling.
** NOTE: I take the computer outside in stages to allow for slower cooling of the components, not an instant inside to outside environment change.
I go from House, to garage, garage to outside (usualy leaving the garage door open a little bit).
