Is vt-d and direct device assignment available on any of vmware's windows based virtualization products ie server?
I am unable to find documentation on this and do not see where to enable it within the gui.
With that said, at least using VMware Player, I can pass-through USB devices to the VM without issue. I know that is something I cannot do in ESXi unless I have IOMMU hardware.
Granted, this isn't an internal device on something like the PCI bus, but worth knowing regardless.
You can pass through USB without using vm directpath i/o in 4.1. It was one of those new flashy features. You can even vMotion to another host while it is connected (serial works too), but the bad part is if you power off / back on you need to do it on the host where it is physically connected. In an enterprise environment I'd go with something a little more hip, like a digi port server/anywhere usb.
KB article linkie...
