vSphere4 environment in a box
All single nested VMs (the ones running directly under workstation) are Bridged, replicating physical state
Tail -f /var/log/vmware/hostd.log.
Try to connect. Should see an mks connection ticket issued. Do you?
You're blaming Windows..I'm gonna blame you. See, now neither of us are at fault!
I will try and update on your suggested resolution this afternoon. I am buried in a CAD system issue for a client that has to get delivered ASAP. The issue is centered around a Dual Quadro FX5800 configuration.
