vSphere 5.5 License Limitations (Essentials Plus)
doofoo
I keep running into conflicting reports on the following question about licensing limitations.
I have a meeting tomorrow with a vendor and vmware to clear them up, but figured I could get ahead of them tonight with the experts on forum here.
I am purchasing vSphere 5.5 Essentials Plus licenses, which I know includes 3 hosts, 2 Sockets/ea.
The vendor is stating that there is a (6) core per socket limitation on the license. I've read, and heard from other vendors that this limitation was removed in 5.1 and 5.5 but can not find evidence of this.
I am about to pull the trigger on servers, and was going to purchase 2 x 8 core per server - if this limitation exists it would waste licenses and I would not be able to run a 3 server cluster due to license exhaustion. Can anyone clear this up for me?
Thanks!
Well this probably does not mean anything, however I have the free version of Esxi 5.5 and just checked the license on it and it shows as being "licensed for 2 physical CPU (Unlimited cores per CPU)".
I checked because I currently have 2x 6 core chips in it and just acquired 2 8 core chips that I plan to swap in this weekend.
The core limitation thing is old. That's gone.
EDIT: But you can't go above 3 hosts w/ Essentials Plus. That's the big limit.
It all depends what you are running. For a small company its plenty.
I have one company 3 hosts AMD clusters 2 CPU 16 Cores a piece and 128 Gigs of ram per host. You can run quite a bit.
Those buying essentials are never going to run 1000+ guests.
Agreed. But just warning people that if you DO plan to ever go beyond 3 it's going to cost you as you have to upgrade host and vCenter licenses.
Or just run multiple instances of Essentials.. Multiple vCenter, etc.. :)
You can't legally. You can only do so if the software is on another "site" there is a ROBO licensing.
You need to purchase Acceleration packs if you want to run more.
I was under the understanding with some of the vmware reps that it's also okay when it's different divisions within the company.
I know quite a few "smaller" companies that have their IT divisions split up where one doesn't have access to the others infrastructure. Those are the situations I have heard it discussed.
I think that's a bit of a grey area. I am not sure to be honest with you.
It depends. Not supposed to have more than one at a single site but as said above, some companies have different divisions w/ different IT and those seem to be fine. Unless you're really taking advantage I doubt your rep is going to care.
