For me, I only ran into two issues at all when upgrading:I downloaded this update on Tuesday this week shortly after release, really looking forward to dropping it on my new ESXi lab system when it arrives (in bits) today. Decided to go the desktop route as opposed to server for this system - a nice AMD Piledriver 8350, 32GB RAM and 2 x 180GB Intel 335 SSD's - I want to test HP VSA running on this and a similar system using network RAID. Also I need to upgrade the second system from 5.1 U1 so it will be a good test of that too judging by the posts above!
1) When upgrading my vCenter server, apparently permissions were "wrong" somewhere in C:\ProgramData\VMWare which caused Access Denied errors... though the installer didn't report these (in fact, reported successful upgrade), the upgrade indeed failed. I attempted reinstalling on a new server, which ended up having its own issues (see #2). So ultimately I deployed vCSA and am happily chugging along again.
2) If you're running vCenter on a Windows Server 2012 machine in a Windows Server 2012 domain, you'll need to grab this patch as well:
http://kb.vmware.com/selfservice/mi...nguage=en_US&cmd=displayKC&externalId=2060901
Good luck!
Eventually it'll all be just the webclient... though I'm not sure how they're going to go about that, unless they issue a vcenter version that's super cheap or free for those who don't buy esx/vcenter licenses.Web client is only for vCenter installations so if you're just running standalone hosts then stick with the normal windows C client. And don't upgrade the VMs to hardware v10, as you'll loose the ability to alter VM settings from the C client.
Had to disable Vt-d and UEFI to get 5.5 install, seems it doesn't like Q67 motherboards never had a problem with 5.1.
Interesting. I tried to upgrade to 5.5 on q67 and there was problems with installation. I also use vt-d so i'll check your solution if it is helpful
For me i lost the ability to use ICH10 as passthrough, did work in 5.0 and 5.1, wonder if it would be possible to switch the drives with the 5.1 ones or something like that.
Are there actual improvements from upgrading hardware past 8? Then again no license so it would be a 60 days test and would still need a windows machine to host the web server etc.
Exact same problem I've seen, if you aren't using vt-d just turn it off. I've played around for ages with various settings combos and bioses without finding a solution other than to disable it. Try again with the next update.
Do you have to get new license keys if you are going from 5.0 to 5.5?
My ESXi box is listed below in my specs but I went from 5.0 to 5.5 and *knock on wood* had a smooth transition to 5.5.
I upgraded 6 of my VMs running Windows to the latest VMware tools and all fully functional but also just using the free license and vSphere Client. The web page doesn't display for me any more.
Unfortunately with free license and vm hw 10you won't be able to configure vm. You need to have vcented with web management - preferably vCSA to access that VMs
Update on this, with a Q77 board as long as you aren't booting off usb it seems to work ok. If you boot from usb it PSODs as per, Q67 boards are SOL all round.I use VT-D for FreeNAS VM so guess i'll have to wait for update/fix and till now use ESXi 5.1U1
Hm...I wanted to connect today ssd as a storage and when i reboot system now everytime when esxi starts i got PSOD. It's PF Exeption 14 just after passthrough module is loaded on the screen.
It helps when i turn off vt-d in the bios - esxi boots. but why it doesn't work with VTD just like that ? :|
Even more bizzare is fact that when i downgraded esxi 5.1 everything works properly. VTD is turned on and i haven't got any errors 0_o
I've tested Esxi 5.5 vanilla and modded with intel nic drivers - both falied to even install now. With uefi of course hangs on acpi. I think that they need to fix that.
HUH??? thats not the same PSOD!!
This PSOD is indicating that something happened with IOMMU not The E1000 Poll if you look at the other PSODs and the KB you will see the lines right after the PF14 event
0xnnnnnnnn:[0xnnnnnnnn]E1000PollRxRing@vmkernel#nover+0xdb9
0xnnnnnnnn:[0xnnnnnnnn]E1000DevRx@vmkernel#nover+0x18a
0xnnnnnnnn:[0xnnnnnnnn]IOChain_Resume@vmkernel#nover+0x247
0xnnnnnnnn:[0xnnnnnnnn]PortOutput@vmkernel#nover+0xe3
This PSOD doesnt match that PSOD event as it never indicates an issue with the E1000 Driver.. The details from the stack will usually indicate where the issue lies, the PF14 is a common error usually indicates HW issues
