Hi,
Maybe a dumb question but let's say I have a network with a single L3 core switch on top that acts also as a internal router. All the used ports on this switch are other switches (some with LAG's).
Then I want to add another same core switch for VRRP redundancy, do double wire all the other switches to the backup one also? I think I would need to use STP too for this to work.
I am a little clueless since it's the first time I'm toying with VRRP.
Thanks
Thanks
