Crashsector
- Jul 10, 2001
Hello again all. I've been pondering something for a while.
I have a SBS2003 server at work and I use the Windows VPN to work on our database and such from home. The VPN itself works very well. I noticed something that made me think though. When connected to the VPN, all web traffic from my home computer gets routed through the server at work.
I know this is probably the fundamental idea behind VPN tunneling, but it makes things quite slow for me since I have lower bandwidth at work than at home.
Is there any way to route traffic with a VPN connection to work so that only the traffic that needs to access resources at work (Windows file shares, Sybase DB connections, etc.) goes through the server at work?
If you don't believe me or are confused, here's a tracert from my home computer when connected over the VPN:
Thanks in advance!
Code:
C:\Documents and Settings\ajuskelis.INVERNESS>tracert google.com
Tracing route to google.com [72.14.207.99]
over a maximum of 30 hops:
1 745 ms 77 ms 148 ms 192.168.1.122
2 308 ms 436 ms 780 ms 192.168.1.1
3 771 ms 131 ms 828 ms <masking my work host> [66.xx.xx.xx]
4 345 ms 425 ms 774 ms 220.ge-0-1-0.cr2.wdc1.speakeasy.net [69.17.83.45]
5 648 ms 155 ms 884 ms eqixva-google-gige.google.com [206.223.115.21]
6 749 ms 795 ms 84 ms 216.239.49.248
7 588 ms 37 ms 38 ms 72.14.236.178
8 115 ms 55 ms 110 ms 66.249.95.122
9 400 ms 108 ms 769 ms 72.14.238.233
10 177 ms 488 ms 452 ms 66.249.94.234
11 404 ms 672 ms 240 ms 72.14.236.181
12 103 ms 797 ms 666 ms 72.14.236.130
13 581 ms 796 ms 691 ms 66.249.94.78
14 559 ms 453 ms 1081 ms 72.14.207.99
Trace complete.
Thanks in advance!
