VPN Help w/ DIR 655
ern
I am new to setting up a VPN and I'm learning but I wanted to know if what I have setup is correct in the router?
This is what I have setup in the router and I have check mark boxes in the ALG section for PPTP, IPsec and the others. I also have the VPN connection on the client machine set to a VPN type of PPTP.
Can anyone tell me if what I'm doing is right and other things of note that I need to know?
Thanks,
This is what mine was using. This forwarded to a windows server 2008 box which was also pptp
Also if you click the dropdown "Computer Name" you can select pptp, I've never used this but I like to think it would work.
