VPN error 623
NewYork
Hi,
I have a computer where I work that I can't find a fix for. It is a freshly installed Windows XP SP3 with all additional updates installed.The problem is when we run the companies generic VPN executable, the response is an error " error 623: The system could not find the phone book entry for this connection".
I am positive that it is system specific because this VPN executable runs on many, many computers here with little to no problems. The problem is that I can't find what is stopping this PC from allowing the VPN executable to run? The VPN icon for the executable never populates under Network Connection where you will normally see it on other machines.
OS__ XP Pro SP3 with all updates (fresh installed a week ago / configured somewhat)
PC__Dell Latitude D430
I've went through the services.msc section and everything looks normal.
I can't select the never dial a connection option under Internet Properties->Connections. It's grayed out. Not sure how to enable this, also not sure if it matters.
On other PC's, you can just run the VPN executable and it just works and asks for your NetID and password. This one errors out before that executable window even loads up pointing to something on the system that prevents it from fully executing.
Any help would be appreciated
Yes, I made a new admin account on this machine for testing purposes. I'm 100% the local admin.
It has to be something related to why that "never dial a connection" is grayed out, just not sure how to get it re-enabled again. Still searching...
There is some weird program installed called "Digital Line Detect". Not sure if I should go ahead and uninstall it or not.
dlg.exe is a part of BVRP Phone Tools software suite. It offers faxing, phone book, e-mailing and more. This is a non-essential process. Disabling or enabling it is down to user preference.
NOTE: The makers of this utility have also made SpyWare in the past. To-date, dlg.exe is not classes as spyware however.We strongly recommend that you run a FREE registry scan to identify dlg.exe related errors.
http://www.liutilities.com/products/wintaskspro/processlibrary/dlg/
It's related to a phone book, lol.
try setting up the standard dialing options, even though you don't use it... ie, area code, etc. Control Panel -> Phone and Modem Options (even if there is modem installed on the machine, it's worth a shot)
the "Never dial a connection" and other options are greyed out, because you don't have any connections created; this option is only available when you have dial-up, PPPoE DSL, Windows VPN, etc connections created.
also... what VPN application are you trying to use?
Sounds like the machine is part of a domain, with a group policy to block changes to the Dial-Up Connections/Connections part of IE.
I'm also assuming that the "VPN executable" is the Windows-based VPN where he can just set it up again from the New Network Connection Wizard in the Control Panel. He probably just needs to know how the encryption and encapsulation are being done.
I had a problem like this before, and it was mainly b/c I had both the Windows-based VPN "AND" the Cisco VPN client installed. It turned out that the Cisco client was taking priority over Windows.
OP/NewYork, who takes care of your desktop support?
Are you in a domain environment?
I'm within a domain but this computer does not sign into AD when the user logons(me or the normal user)
I really don't think so.
I'm not sure because they claim to have made it but someone told me they just renamed everything on it so.... It just say the name of the company everywhere.
Did that, no go.
You lost me, lol.
Thanks ffor the help fellas but still nothing.
I tried to re-register the raspi32.dll but got the error,
rasapi32.dll was loaded, but DLLRegisterServer entry point was nmot found.
The file can not be registered. Click Okay.
That doesn't matter, what matters is if the computer is a domain member or not. If you right click on my computer and go to the computer name tab what is shown?
If it's: <computername>.<somedomain>.com you're a domain member and it is very likely that domain policy is causing your problem.
I just checked and this is not a member of any domain. It is set to workgroup.
:confused:
What I meant earlier is that the IP address this computer receives is given from the companies router(inside the domain)(not sure that even matters).
the computers this does work on... do they have an additional connections created in Network Connections?
They have the normal local area connection and then the VPN connection for this program. However on this machine, that VPN never appears in Network Connection. That's got to be part of the problem is that it can't get added into something that will allow it to populate in that area. Just not sure where or what.lol
This is what it should look like. But the system with the trouble will error out before that gets put there.
(I brushed out the companies name, fyi)
And just to reiterate. I keep reading stuff saying that you must select "never dial a connection" but it's grayed out/not an available option.
:confused:
Here's the problem. Two actually.
1. Area is grayed out
2. If I try and add something under dial-up and VPN section, I get the error below the Internet Properties window.
Here's the big issue though when the VPN is run.
:confused:
It's grayed out because you have nothing in the "Dial-up and Virtual Private Network settings" dialog.
*edit
Try this link.
http://support.microsoft.com/kb/320693
This was the first thing I found in google at 8:00am this morning. It does not help. Unless I completely missed something. You can't populate that section or you get the error below that picture I linked above of the Internet Properties window.
try to create a new connection through the Add New Connection wizard within Network Connections, just for giggles.
edit: maybe of some help?
1. Make sure that RASPHONE.PBK is located in system32\RAS\. If so, rename the file and run RASPHONE.EXE. If not, then run RASPHONE.EXE.
except it appears rasphone.pbk exists in: C:\Documents and Settings\All Users\Application Data\Microsoft\Network\Connections\Pbk for XP
edit1b: Here's the Microsoft KB on rasphone.pbk issue http://support.microsoft.com/kb/812442
edit2: another possibility http://www.tomshardware.com/forum/87055-45-duns-error
Thanks, will give another go tomorrow.
I really appreciate it too, Thanks.
This is kind of stating the obvious, but I think the 624 is the root of your problem. For whatever reason, it can't write to the phonebook file. The VPN executable fails to create its own connection due to this issue, then gives the 623 error because it can't find the connection, due to not being able to write to the phonebook. I think j-sta has the right idea.
j-sta
I was able to get the VPN to load using the provided information.
I get a new error 781 now but I'm working on it.
Thanks
The VPN executable still does not load normally. I can get it to at least pop-up because I run rasphone.exe and make a VPN connection associating it with the vpn.address.com of the company. I can click connect, the VPN executable pops up/loads and gives me error 781(error 781: Encryption failed because no valid certificate was found. ) when I put in my credentials to connect.
But then if I just try to load the VPN executable by itself, I get the same error as before, error 623. Something is not sticking, not sure what though. There has to be something I'm not doing or something stopping the addition of a VPN connection somewhere.
What I know:
If I delete any rasphone.pbk file file and then run rasphone.exe(with just something to populate the phonebook or the correct VPN address), the new rasphone.pbk get populated in
If i then run the VPN connection using the rasphone window itself, it will work(but a different "error 781" when I enter my credentials), if I run the VPN executable, the same error 623.
And even when those are added using rasphone.exe, they never populate into this section.
But the made connections will show up under the normal "Network Connections" in control panel.
But not the one that the VPN executable should make in there like it does on normal working machines.
this is for error 781.
This error may occur with Windows 2000 or XP client attempting to connect to a virtual private network (VPN) using Layer 2 Tunneling Protocol (L2TP) and IP Security Protocol (IPSec).
If you are attempting to connect with VPN, L2TP or IPSec:
There may be a problem with the remote computer:
The certificate on the VPN server is not valid or missing - the administrator of the remote computer must correct the problem.
The IPSec Policy Agent service on the remote computer may be stopped, or stopped and re-started without stopping and re-starting the Routing and Remote Access service on the server. The administrator of the remote computer must correct the problem.
For more information - see MS KB 247231
couple things to try/check
also, on the computers this does work on, are they showing a connectoid in that connections window?
maybe there's a connection that needs to be created before that executable works?
what I would do then, is view the settings of that VPN connection, then manually create it on your laptop, then run the executable.
There's gotta be a step missing somewhere.
The funny thing is that I don't see an easy way to check the settings that are being configured/made. I believe those are hidden. I just asked the guy that claims to have made the VPN tool and he just responded back with this.
I’m not entirely sure who maintains that manual or where you might find it. I suspect you could probably take the Mac instructions and convert them to Windows. I don’t believe you will find much difference between the VPN connection and the hand made one but it’s not a bad test.
I just highly doubt the Mac settings will help me much.
all you really need, since it essentially creates a (basically generic) Windows connectoid, would be IP address/domain/host name and type of encapsulation (PPTP, IPSec, L2TP).
Tried to setup the VPN manually, it still would not work but the same settings worked on another windows xp machine. We're running out of options so may just reformat this bitch.lol
Something is just stopping (VPN) connection making.
Tried...
Uninstalled DUN/RAS
Manual VPN configuration
Winsockfix (just tried it)
Replaced phonebook with one from working machine
Deleted all phonebooks and reran rasphone.exe
Some registry settings (reverted back when they didn't work after reboot)
Reset windows firewall
Some other things I'm probably forgetting
Thanks for the help though guys.
verify the IPSec service is running on the machine?
assuming the VPN uses IPSec encapsulation.
We ended up reinstalling to an XP image, installed the drivers, loaded up the VPN and it worked right away. There was definitely something wrong with that XP image but it was taking too much time so we just saved time.
The funny thing is now someone has this same error on a Windows 7 Enterprise(64 bit) machine. We'll see if we can mess with that one for a fix. We did already verify that the IPSec service was running too. It was set to manual and we set it to automatic for giggles. Nothing. Although this Windows 7 machine is running on a Macbook Pro off bootcamp. Not sure if installing it that way may have left something out of the install or what but we'll hopefully see with this one.
