I just got a Viewsonic VP171s, and I'm using it via analog with my ti4200
I think the optimal settings are 60hz at 24bit-depth, but I can only select 16 or 32bit, and when I try 60hz at 16 bit, half the screen is shifted off. So I'm stuck at 16-bit at 70hz.
I installed the monitor drivers, how can I set it up? Any overrides with riva tuner?
