Napalm Frog
- Jun 21, 2002
Okay, I didn't notice this until today, but my music sounds different depending on the volume I have my devices set at. There is my PC (Foobar via WASAPI), Fubar III, then M-Audio AV40 (I have the headphone amp in the middle because I use my headphones a lot).
Obviously, when I make either the Fubar or the AV40 the music goes louder. However, the ratio of volumes produces differences in the low end (I'm a bassist and I can notice it immediately... for all I know, there is difference in the highs as well). When the AV40 is high and the Fubar low, it sounds normal: tight, punchy bass. When the Fubar is high and the AV40 is low, the low end sounds "fuller". Not muddy or anything, just more rounded (if that makes sense).
I assume this would be normal, I just need to tweak to get the right sound that I want. Is there any advice you can give me regarding this? Or should I just connect the AV40 to on-board sound, and the headphones via the amp, despite the audio out on it?
