Volume Problems
Panda Man
I am having some problems with my speakers. The volume constantly goes up and down. It normally it just changes a little bit, however sometimes it will sky rocket and then become very quiet (though rare). Normally I would assume its a hardware problem, however this ONLY happens in Winamp and ePSXe. It doesn't happen in BF2, CoD2, or even in Windows Media Player Classic (It doesn't happen in winamp sometimes). I've already updated my drivers, and checked all the connections. I've tried different plug-ins in winamp, and though it did help the volume problem it just made new ones by causing the sound to be distorted. So i'm stuck to my current plugin. The biggest problem is in Winamp, ePSXe has the same problem as stated before but not as bad. I've used these plugins on different comps, and they worked fine then so i know they are stable. I've also checked the volume control in windows, and it doesn't change either. I've even gone so far as to format (Yea, i listen to winamp alot - it was worth it). So, now I'm not sure what to do. Any ideas?
