I was curious as to how loud 95db sounded like and realized that I have no easy way to tell. So I thought to calculate out the maximum volume of my Ipod Touch with a Shure SCL3 and estimate.
So what I know:
Shure SCL is 115db/mW with 26ohms impedance.
Ipod Touch outputs 30.6mW at 10ohms.
So Power = Voltage^2/Resistance. 30.6mV = V^2/10. V is constant so it would be 11.7mW.
11.7mW /1mW is 11.7 times the power. Doubling the power results in 3db. 3*log2(11.7)=10.6db. So the maximum db is about 125db.
So if I set my volume bar to about half, that should be around 62db? Or is there much more to this? Thanks.
So what I know:
