From what I've read it isn't recommended to run a volt-mod on a GT AGP (from 1.3v to 1.4v) because it is missing the required VC's and a second molex connector (and this causes the card to die after a few months unless you're lucky). Well what about PCIe? If you look the Ultra and GT board appear to be exactly the same, seems the only physical difference is the HSF unit and both only require one 6-pin PCIe power connector (I think this is because the card can draw enough power from the PCIe slot to not require two connections). Considering a PCIe Ultra and GT are exactly the same physically and such do you think it would be alright to pump 1.4v into a PCIe GT? If it isn't apparent I'm talking about 6800 Series card's here. Looking forward to your replies.
