voltages
Ok, basically I'm worried about my cpu voltage. On the retail box it says 1.55MAX. When I have the BIOS settings for vcore on auto I get 1.65ish volts. I adjust in BIOS to 1.55 which is the lowest setting for my mobo and I'm still at 1.63. Thought it might be misreading with the ASUS probe utility, so I check CPU-Z and its the same number. What gives? And are these voltages dangerous and huring my cpu? Cause I know that 1.7v will just about fry your cpu (from what I've read on other's posts).
Called Intel and they were no hope. Told me to flash my bios. Got the newer version and same thing. Any sugestions, advice, comfort, pity etc?
yea, mine runs about 1.6 also, I wouldn't worry too much about it. Now that you've said that it seems like it might just be either an optimization or a misreading that ASUS boards have.
