âVelocitymasterâ
- Dec 12, 2004
I have QX6700 CPU with Zalman 9700 cooler
Evga 680i SLI A1 mobo
2 gigs Corsair Dominator running at 1120 mhz
Win XP Pro
Idle temps at 47c max load at 62c
I ran memtest and no errors at all for 6 hours.
My CPU is clock at 3.2ghz from 2.66 stock , multiplier is X10 FSB clock 320mhz
Not sure what volts to be in at this speed any one?
I have mine set at 1.34v
ram is at 2.2v which is manufacture default spec.
FSB volts at 1.40
nForce volts at 1.52
I run stable at encoding videos and Super pi in all test. In Orthos when i get to smaller FFT like 32, after 5 min my computer freez, can't alt tab or ctr-alt-del. I had to hit reset to restart the machine. I ran 1024fft and it was running fine. I run prime for 2 hours and it did fine.
Whats going on, Im i setting something wrong.
Win XP Pro
FSB volts at 1.40
