- Apr 11, 2007
When applying voltage to my CPU should I be more concerned over what is set in the bios or what CPU-z is reading? I guess I'm a littel confused over this.
tbh all readings from a PCs sensors need to be taken with a pinch of salt.
They might be dead on right but they can also be wildy inaccurate.
I wouldnt worry about them too much unless you find that the readings are so bad it affects what you need to do.
Use the readings as a guide to any changes that are ocurring, like temps rising or voltage fluctuating a lot.
You cant trust the absolute values.
Chances are they are going to be within 10% of the real figures but there is NO guarantee.
There is no way to know the exact voltage applied to your CPU unless you measure it with a calibrated meter.
Most decent meters you can buy these days are within a couple of % accurate or better.
Also worthy of note:
Once you have set a voltage in the BIOS, the voltage to your CPU will not remain constant.
The more load applied to your CPU, the more power it will require and thus more current will flow
Due to resistance in the power circuitry, the more current that flows, the more voltage will drop across these circuits, thus reducing the actual voltage fed to your CPU.
Its the same for everyone.
Some motherboards have compensatory circuits to keep the voltage more stable but there will be a variance no matter what.
Its nothing to worry about unless the constantly changing variations get really big and affect your stability.
