voltage meter?
Zakter
Is there a program that can tell you the voltage|power usage your PSU is currently using/running at?
You'll need a hardware device to do this - except maybe for server equipment with power monitoring features (which I doubt you have).
If you want to measure the AC power consumption of your computer, your best bet would be to pick up one of those Kill-a-watt devices that you plug the computer's power cord into.
Thanks for the input! It turns out I have an ultra bad power supply installed right now.
Turbolink LC-A420ATX
I need a replacement PSU that will handle an 8800 GT card with my current hardware.
