Voltage Locked on A64!!
BakedGoods
I just got a A64 3400+ CH CG setup witha DFI LanParty NF3 board. When I try to change the voltage the selection box maxes out at 1.550v, yet I've seen people getting 1.6v. What's the deal? How can I unlock my mobo to see ALL the volts that I can change to?
Thanks!
it is in the bios, the very next line below the manual CPU voltage adjustment you are speaking of/found.
it will allow for 104%, 110%, 113% and higher, that is where you get your 'extra' boost.
while you are in the bios, cruise around and get familiar with the many options, it is a little different than what you may be used to.
good luck.
baldy :)
Thanks! I found that option, sadly though, my system wouldn't reboot after a 110% volt increase =(
