Voltage Issues on the Neo2 Platinum
dynamiks
Okay let me start by saying, I know the overclock I have already is good but I have a feeling I can achieve higher, but I am having voltages issue with the board.
Okay right now I have an AMD 64 3000+ Winchester. I have been able to hit 2.6Ghz so far stable. Now I hope I get this right the first time, I will try not to leave out any details of all my settings.
My setup looks like this. Memory is running at 2.5-4-4-10 (5:4). HTT = 3x, FSB = 306Mhz x 8.5 multi. Voltage is at stock (1.4) x 10.0% and its reading between 1.55-1.58v in CPU-Z. AGP is at 67Mhz, HD is on SATA 3. Memory is at 2.85v. I am using Corsair TWINX PC-3200 1GB (512x2) (2-2-2-5) memory. My Bios is 1.41 modded bios.
Okay I think thats everything, I hope I didnt miss nothing.
Anyway, my problem now is, whenever I try to achieve a voltage higher than 1.55, the computer will not boot. I have tried in different variations. I have tried 1.4 x 13%, and 1.55 x 3%. To try to get about 1.6v to maybe reach 2.7Ghz on my CPU, but whenever I up the voltage, the comp wont even boot up, and I have to power down the system and reset the BIOS on the motherboards jumper. My question basically is there something I am doing wrong, because I know I should be able to get my voltage higher than this. I am not being greedy, I know I already have a good overclock, but I am curious to see if I can get it higher, and I dont understand why it's not working out. I've seen people up there voltages to 1.7, with high overclocks like 2.7, 2.8Ghz, etc. Anyway any help would be appreciated.
Thanks
Try with 1.36B mod bios and add vcore on core center. Htt306 kinda too high? Back down a bit....
do *not* use a 1/2 multi. it does you no good, other than jack up the htt speed needlessly.
about the voltage: i don't know. the neo2 is a vastly different board than the neo, and i've never had that sort of problem. good luck getting it sorted out though
