Since I switched to water cooling, I figured I would try dropping the voltage to my cpu. I was thinking lower temps with w/c maybe means that not so much voltage is needed. So I dropped my volts to 1.8 from 1.9. By the way my system was not stable below 1.9 on air.
Well, it works!!
Load temp dropped 5 degrees celcius and processor is still stable..
Is this normal? Can voltage be dropped more if cpu is runnning cooler??
Well, it works!!
