Voltage Drop on P4E, normal?
BossNoodleKaboodle
According to the voltage section of Aida32, my CPU core voltage drops from the normal 1.38ish range to 1.30 under load.
Is this voltage drop a problem? If so, would it be the new Enermax PSU I got? Its 550 watt and rated to handle Dual Xeons. Bad voltage regulator on the mobo?
