Voltage at max, what now?
Hello all,
I'm running an ASRock Dual939-SATA2 with an AMD Athlon 64 4000+ San Diego. I just checked into my BIOS, and I am at maximum voltage just to run the CPU. Is there any way I can overclock it without adding voltage that I don't have?
Thanks in advance :)
you shouldn't have to bump up the voltage for stock speeds, something is wrong with either your motherboard, cpu or BIOS.
There's a vcore mod for that board yknow :). Goes up to 1.55v
Google it!
Or, just tweak your timings, get your RAM as fast as possible... and call it a day.
There is a beta bios that is supposed to help with turning up voltages to oc your board....hope this helps...... Ice
On mine, i had most luck with OCWB1 and the 1.55 vmod. Which is a pencilmod. Very quick and easy to do.
