Garzilla04
- Oct 26, 2003
Well I just bought a Volcano 9 off of my friend. I then proceeded to take off my old heatsync with no problems. Ok so I put on the Volcano 9, and plug one of the two fan cords into a power supply. I figured the other one was for the temp sensor or somethin. So I turned my comp on, everything is cool....my desktop shows up for about 3 seconds...then my whole computer shuts down....
. So I plugged in both fan cords....same thing, I looked on the Thermaltake site and something was mentioned about jumpers. So do I have to put a jumper on the cord that isnt being used? Any help is cool, thanks.
