Volcano 8 fan lowering dbs?
Qwertyman
how do u lower this fan's noise it is loud as hell. can i lower the voltage or something cause it runs at 4800+/- rpm.
Does it have a thin 60 mm fan on it? I'd suggest replacing it with a taller fan. That should cut down on the noise a little. :)
Originally posted by Qwertyman
would it lower the cooling efficiency, i'm assuming yes
It will. In some cases, slowing fans a little can increase efficiency, but usually it does not.
