VOIP PBX
Metraon
Is that a good idea to put the PBX with the POE switch ?!
I have this setup :
Modem === Router (Edgerouter) ==== SWITCH (HP 1810-24v2) === POE SWITCH (4 phones + PBX)
or should I do something like this :
Modem === Router (Edgerouter) ==== SWITCH (HP 1810-24v2 + PBX) === POE SWITCH (4 phones only)
or I could plug the switch in one of the edgerouter free ports ?
The POE switch is a Planet GSD-808HP. Should I VLAN the port on the HP to separate traffic ?
Thanks!
Plug the switch into a port on the router. Plug the phones and everything else into the switch.
But the HP 1810-24v2 is not poe (i think) ? I need the Planet GSD-808HP to power the phones.
