Ive read quite a few SATA problems that are similar, but I cant find one with exactly my problems. Heres my setup
Chaintech VFN3-250 mobo [amd64 3200+ 2x512@400mhz memory]
IDE0 - Master - Maxtor 80gb IDE **[old boot drive]**
IDE0 - Slave - WD "Deathstar" 45gb IDE
IDE1 - Master - WD 20gb IDE
IDE1 - Slave - DVDRW IDE
IDE2 - Master - Maxtor 120gb SATA **[new boot drive]**
IDE3 - Master - None
Heres the problem, when all this is like it apears above, I get an error after the "Verifing DMI Pool..." to "INSERT VALID BOOT DISK" or whatever the exact message is. If I unplug all of the IDE0 then I can boot normally with the SATA into windows, the IDE1 channel works fine. However if I unplug IDE0-Master but leave IDE0-Slave, I get a windows cannot start, corrupt file <windows>/hal.dll warning.
Ive tried messing around with the BIOS in every possible way it seems :-/
HELP!
HELP!
